E-Mail Us
It is currently Thu Feb 27, 2020 3:59 am
Post new topic  Reply to topic  [ 189 posts ]  Go to page Previous 1 2 3 4 519 Next
Author Message
 Post subject: Re: Podcasts Gallery
PostPosted: Wed Apr 21, 2010 1:57 pm
Not sure if I have done this correctly, but I have added more categories to BBC iplayer
Movies,Comedy,Children,Drama,Sport,Entertainment,Factual,Learning,Lifestyle & Leisure,Music & News
BBC iplayer.7z [2.59 KiB]
Downloaded 1556 times
Top
PostPosted: Thu Apr 22, 2010 11:27 am
Hulu (http://www.hulu.com) (required version 1.51)
hulu.zip [4.83 KiB]
Downloaded 1283 times
2. Drag and drop hulu.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Hulu. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file hulu.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "Hulu", you can update the list of podcasts.
:!: Service only available in the United States :!:
2011/08/06 Updated
2012/05/21 Updated (added support for the mode "The script generates a few links (the call while navigating on the device)")
2012/09/27 Updated
Top
PostPosted: Thu Apr 22, 2010 11:31 am
TheWB (http://www.thewb.com) (required version 1.75)
thewb.zip [5.23 KiB]
Downloaded 965 times
2. Drag and drop thewb.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "TheWB - Shows". If the folder does not appear (Windows 7, Windows 8, Windows Vista), then the program and Explorer are running with different rights. Try to load the file thewb.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "TheWB - Shows", you can update the list of podcasts.
Updated 2010/05/27 (videos from hulu.com)
Updated 2010/06/16 (added shows links)
Updated 2011/01/20 (updated shows links)
Updated 2013/03/05
Top
PostPosted: Fri Apr 23, 2010 8:33 am
Comedy Central (http://www.comedycentral.com) - Colbert Nation, The Daily Show With Jon Stewart, South Park
comedycentral.zip [6.63 KiB]
Downloaded 1026 times
2. Drag and drop comedycentral.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Comedy Central. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file comedycentral.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "Comedy Central", you can update the list of podcasts.
Updated: 2010/05/05
Updated: 2010/05/27
Updated: 2011/01/02
Updated: 2011/04/04
Updated: 2011/08/07
Updated: 2012/08/03
Updated: 2013/05/02
Top
PostPosted: Tue Apr 27, 2010 1:45 pm
Marvel (http://www.marvel.com) - (required version 1.05)
marvel.zip [9.64 KiB]
Downloaded 958 times
2. Drag and drop marvel.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Marvel. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file marvel.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "Marvel", you can update the list of podcasts.
2010/06/10 Not work :(
2010/09/06 Updated
2010/11/27 Updated
2011/04/04 Updated
2013/05/04 Updated
Top
PostPosted: Tue Apr 27, 2010 1:48 pm
Fox (http://www.fox.com) - (required version 1.09)
fox.zip [4.68 KiB]
Downloaded 1670 times
2. Drag and drop fox.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Fox. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file fox.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "Fox", you can update the list of podcasts.
2011/04/04 Updated
Top
PostPosted: Tue Apr 27, 2010 2:00 pm
Babelgum (http://www.babelgum.com) - (required version 1.07)
babelgum.zip [8.92 KiB]
Downloaded 1367 times
2. Drag and drop babelgum.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Babelgum. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file babelgum.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "Babelgum", you can update the list of podcasts.
Updated 2010/10/27
Updated 2010/11/12
Top
PostPosted: Thu Apr 29, 2010 10:06 am
Amazon on Demand (Preview) (http://www.amazon.com/b/?&node=16261631) (required version 1.05.1)
amazonpreview.zip [2.29 KiB]
Downloaded 1393 times
2. Drag and drop amazonpreview.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Amazon on Demand (Preview). If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file amazonpreview.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "Amazon on Demand (Preview)", you can update the list of podcasts.
Updated 2010/10/26
Top
PostPosted: Sun Jun 06, 2010 11:15 am
Youku (Chinese) (http://www.youku.com) (required version 1.0)
youku.zip [2.25 KiB]
Downloaded 1221 times
2. Drag and drop youku.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Youku (Chinese). If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file youku.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "Youku (Chinese)", you can update the list of podcasts.
Updated 2010/10/19
Updated 2012/11/04
Top
PostPosted: Thu Jun 10, 2010 3:48 pm
Watch Free TV Shows (http://watchfreetvshows.info/) (required version 1.05)
watchfreetvshows.zip [4.29 KiB]
Downloaded 2047 times
2. Drag and drop watchfreetvshows.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Watch Free TV Shows. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file watchfreetvshows.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder Watch Free TV Shows, you can update the list of podcasts.
For owners Megavideo.com Premium account
1. Open video page on Megavideo.com (login required) in IE.
2. On right click "View source"
3. Ctrl + F: flashvars.userid =
4. Copy userid to clipboard.
5. WMS - Watch Free TV Shows - right click - Edit title - "Script for the links to the resource" - Edit script - paste your userid in line csMegavideoUserID = ''; between '
2010/09/13 Updated
2019/09/19 Updated (for owners Megavideo Premium)
Top
Search for:
Jump to:
cron
