E-Mail Us
It is currently Tue Mar 19, 2019 5:06 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
Author Message
PostPosted: Thu Mar 23, 2017 7:03 pm
Update to 2.81 (x32) (2.80-2.81)
Update to 2.81 (x64) (2.80-2.81)
Wild Media Server (UPnP, DLNA, HTTP) v.2.81
1. Settings - Transcoder:
  • added the page "Format parameters" - setup parameters for used formats of transcoded files.
2. Device settings - Transcoder - Codecs, frame - File format:
  • added formats MKV, HLS, WEBM, DASH, ISMC, HDS.
3. Device settings - Transcoder - Codecs, frame - Video - Codec:
  • added format VP9.
4. Device settings - Transcoder - Codecs, frame - Audio - Codec:
  • added format VORBIS, OPUS.
5. Updated transcoder ffmpeg-1.dll (version 3.2.2), added support for encoding VP9, VORBIS, OPUS.
6. Scripts:
  • added function WmsTranscodingFormatParams - returns the format parameters by name from the settings page "Format parameters".
7. Torrent-files:
  • added support for original file transfer via the folder Transcoding - Movie folder - Original.
8. Changes in transcoding profiles to use WmsTranscodingFormatParams (if the transcoding profiles changed, it is recommended to restore the profiles from the distribution kit for support new formats of transcoded files).
Top
Search for:
Jump to:
cron
