E-Mail Us
It is currently Thu Jun 30, 2022 11:23 pm
Post new topic  Reply to topic  [ 2 posts ]
Author Message
PostPosted: Mon May 07, 2012 5:36 pm
Required version 1.51
These function and the class may be useful for reading tags of files, that the program does not handle by default (for example in the event "After reading of properties of a media resource").
Example simply display the tags of current media-resource in the List [Movies, Music, Photo]
Settings - Processing - Add
Check "Button on the main form"
Script:
Code:
  FileTags: TWmsScriptFileTags;
  TextTags: TStringList;
  sProviderName, sValue: string;
  if InputQuery('Provider Name', 'Exif, FFmpeg, MediaInfo, Shell, Wms, Xmp', sProviderName) then begin
    FileTags := WmsCreateMediaItemTags(sProviderName, WmsCurrentMediaListItem);
    if FileTags <> nil then try
      TextTags := TStringList.Create;
      try
        for i := 0 to FileTags.GetTagCount - 1 do begin
          sValue := VarToStr(FileTags.GetTagValue(FileTags.GetTagID(i)));
          if (sValue <> '') and (Length(sValue) < 100) then
            TextTags.Add(Format('%s (%s): %s', [FileTags.GetTagName(i), FileTags.GetTagID(i), sValue]));
        ShowMessage(TextTags.Text)
      finally
        TextTags.Free
    finally
      FileTags.Free
Ok - Ok
Select a media-resource - click "Display Tags" - specify a provider name - Ok
Top
PostPosted: Tue Jan 22, 2013 1:19 pm
Example of use WmsMediaInfoCreate, for a video track (Stream_Video), the possible values ​​in description of the type TMIStreamKind
Code:
  i, iCount: Integer;
  sValue: string;
  if WmsCurrentMediaListItem <> nil then begin
    if WmsMediaInfoCreate('', WmsCurrentMediaListItem.ItemID) then begin
      try
        iCount := WmsMediaInfoGetCount(Stream_Video);
        for i := 0 to iCount - 1 do begin
          sValue := VarToStr(WmsMediaInfoGetI(Stream_Video, 0, i));
               WmsMediaInfoGetI(Stream_Video, 0, i, Info_Name_Text),
               WmsMediaInfoGetI(Stream_Video, 0, i, Info_Name), sValue]));
      finally
        TextTags.Free
Top
Search for:
Jump to:
cron
