E-Mail Us
It is currently Sun Jul 21, 2019 9:45 pm
Post new topic  Reply to topic  [ 5 posts ]
Author Message
 Post subject: Swedish podcasts
PostPosted: Mon Feb 13, 2012 6:03 pm
SvtPlay - http://www.svtplay.se
svtplay.zip [113.52 KiB]
Downloaded 633 times
2. Drag and drop svtplay.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear SVT Play. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file svtplay.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder SVT Play, you can update the list of podcasts.
You can update the list of programs: select the folder "Kategorier" or "Program A-Ö" - right click - "Create podcast feeds"
Updated 2012/02/16 (support for flv and live streams)
Updated 2012/07/05
Updated 2012/07/10 (support for klipp)
Updated 2012/09/29
Updated 2012/11/03
Updated 2013/01/05
:!: Restriction of the region - Sweden
Top
 Post subject: Re: Swedish podcasts
PostPosted: Thu Jul 05, 2012 1:09 pm
New version
Top
PostPosted: Sat Sep 29, 2012 9:29 am
New version
Top
PostPosted: Sat Nov 03, 2012 7:50 am
New version
Top
PostPosted: Sat Jan 05, 2013 1:05 pm
New version
Top
Search for:
Jump to:
cron
