E-Mail Us
It is currently Sat Jan 19, 2019 3:03 am
Post new topic  Reply to topic  [ 1 post ]
Author Message
 Post subject: Folder "Search Text"
PostPosted: Sun Nov 18, 2012 6:38 am
Requires software version 1.59 (32-bit), 1.59 (64-bit) or higher.
searchtext.zip [1.48 KiB]
Downloaded 959 times
2. Drag and drop searchtext.wdf from Explorer to main form of program.
If the loading is successful, then under Movies folder appears the folder "Search Text". If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file searchtext.wdf by right click in the folder tree.
Folder "Search text" uses a new folder type - "Dynamic (script) - depended on the device", a list of media resources are the English letters, while browsing the user creates the search text, which is stored in the device properties and may be used (function WmsGetUserSearchText) in other scripts, such as podcasts. If the devices are limited to a depth of navigation, the continuation of the text in the folder "Continue".
Youtube - added the folder "Search Text"
Top
Search for:
Jump to:
cron
