E-Mail Us
It is currently Wed Dec 01, 2021 7:06 pm
Post new topic  Reply to topic  [ 6 posts ]
Author Message
 Post subject: HTTP Pseudo-Streaming
PostPosted: Fri Mar 02, 2012 7:08 pm
Is it possible to request certain position via uri eg. '/MediaServer/VideoItems/T-b70621a57705fe26c75f3a900374753e.mp4?mpTimeStart=500' which will be registered to mpTimeStart variable?
Top
PostPosted: Fri Mar 02, 2012 7:46 pm
In any case, the player does not understand the answer (mp4 specific)
Top
PostPosted: Fri Mar 02, 2012 8:33 pm
So is there any way I can call a specific time from the http link other than using the time interval?
Top
PostPosted: Sat Mar 03, 2012 6:30 am
For mp4, I think, it's impossible (only with transcoding or play from the beginning and GoTo).
Top
PostPosted: Sat Mar 03, 2012 1:16 pm
Let's say it's not only for mp4, is there any way I can offset to a specific time during transcoding from the web-navigation by using URI query eg. "?starttime=500". I've embedded a JW Flash Player into the WMS web-navigation. It can play the ffdshow transcoded content, only problem is that I can't forward to a part where the content hasn't been loaded. JW Flash Player supports HTTP Pseudo-Streaming where the player can call the time offset using URI. I just need to know how to implement this with WMS via URI.
Top
PostPosted: Sat Mar 03, 2012 2:03 pm
You can try TimeSeekRange.dlna.org: npt=500.00- in request header, but it will be a transition based on file size.
Top
Search for:
Jump to:
cron
