E-Mail Us
It is currently Wed Sep 23, 2020 10:07 am
Post new topic  Reply to topic  [ 40 posts ]  Go to page 1 2 3 4 Next
Author Message
 Post subject: SopCast
PostPosted: Wed Jan 27, 2010 2:43 pm
Me again Eugene,
Does your wonderful program support the live playing of Sopcast files? Some sports are available via SopCast. I can view them on my PC by using the downloaded Sopcast application, but would be nice to watch them on my Sony TV.
Kind Regards
Top
 Post subject: Re: SopCast
PostPosted: Wed Jan 27, 2010 3:24 pm
You must configure the view in VLC, then the flow can be redirected to the TV.
Top
PostPosted: Wed Jan 27, 2010 4:00 pm
Sorry, I'm really lost on this one. Please can you give me instructions/screenshots step by step?
:oops:
Top
PostPosted: Wed Jan 27, 2010 4:07 pm
:oops:
I do not use sopcast, there will be news, I will inform.
Top
PostPosted: Wed Jan 27, 2010 5:17 pm
1. Download and install SopCast SopFilter 3.0.3 (http://www.sopcast.com/download/)
2. Settings-Transcoder-Profiles-Add
Name: Internet-television (SopCast)
Execute mode: Transcoding
Language: PascalScript
Transcoding parameters:
Code:
  sTranscoderParams: string;
  if WmsDirectShowAddSource(InputFileName, 'Source') = S_OK then begin
    mpInternetItem := False;
    sTranscoderParams := WmsTranscodingProfileParams('Movies (primary)') + ' "<OUTPUT FILE>"';
    TranscodingResult := WmsTranscodingExecute('WMSMPEG', sTranscoderParams, True,
                                 'http://localhost:8902/tv.asf', OutputFileName)
  end else
    TranscodingResult := False
3. Ok-Ok-Ok
4. Select folder "Internet-televison", on right button mouse in List [Movies] - Add link
5. In field "Path": sop://....,
6. Ok
7. On right button mouse - Transcoding profile "Internet-Television (SopCast)"
8. On right button mouse - Test transcoding
Top
PostPosted: Wed Jan 27, 2010 7:44 pm
Script for create sopcast channel list ('http://www.sopcast.com/chlist.xml') in Internet-television folder
1. Settings-Processing-Add
Turn on "Button on the main form"
Expression:
Code:
  CSIDL_LOCAL_APPDATA = $001c;
  mpiTranscodingProfile = 50;
function GetItemValue(aItem: TXmlItem; const aValueName: string): string;
  Item: TXmlItem;
  Item := aItem.Find(aValueName);
  if Item <> nil then begin
    Result := Item.Attributes['en'];
    if Result = '' then
      Result := Item.Value
  end else
    Result := ''
  ChannelItem, GroupItem, SopAddressItem: TXmlItem;
  SopItem: TWmsScriptMediaItem;
  sChannels, sFolderID, sGroupName,
  sChannelInfo, sChannelAddress, sFolderPath,
  sStreamType, sSubFolder, sTranscodingProfile: string;
  XmlDocument: TXmlDocument;
  i, iUnknownCount, j, k: Integer;
  XmlDocument := TXmlDocument.Create;
  try
    XmlDocument.LoadFromString(ReplaceStr(WmsDownloadURL('http://www.sopcast.com/chlist.xml'), #13#10, '  '));
    iUnknownCount := 1;
    if SameText(XmlDocument.Root.Name, 'channels') then begin
      for i := 0 to XmlDocument.Root.Count - 1 do begin
        GroupItem := XmlDocument.Root.Items[i];
        if SameText(GroupItem.Name, 'group') then begin
          sGroupName := GroupItem.Attributes['en'];
          if sGroupName = '' then begin
            if (GroupItem.Count > 0) and (GroupItem.Items[0].Name = '') then
              sGroupName := Trim(GroupItem.Items[0].Value);
              sGroupName := GroupItem.Attributes['cn'];
                sGroupName := Format('Unknown (%d)', [iUnknownCount]);
                Inc(iUnknownCount)
          sFolderPath := 'SopCast Channels\' + sGroupName + '\';
          for j := 0 to GroupItem.Count - 1 do begin
            ChannelItem := GroupItem.Items[j];
            if SameText(ChannelItem.Name, 'channel') then begin
              sChannelInfo := Format('%s; Class: %s; Region: %s; Language: %s',
                                     [GetItemValue(ChannelItem, 'name'),
                                      GetItemValue(ChannelItem, 'class'),
                                      GetItemValue(ChannelItem, 'region'),
                                      ChannelItem.Attributes['language']]);
              sStreamType := GetItemValue(ChannelItem, 'stream_type');
              if SameText(sStreamType, 'mp3') or SameText(sStreamType, 'wma') then begin
                sFolderID := mfAudioInternetRadioItemID;
                sTranscodingProfile := 'Internet-radio (SopCast)'
              end else begin
                sFolderID := mfVideoInternetTelevisionItemID;
                sTranscodingProfile := 'Internet-television (SopCast)'
              SopAddressItem := ChannelItem.Find('sop_address');
              if (SopAddressItem <> nil) and (SopAddressItem.Count >= 1) then begin
                for k := 0 to SopAddressItem.Count - 1 do begin
                  if SopAddressItem.Count > 1 then
                    sSubFolder := '\Item' + IntToStr(k + 1)
                  else
                    sSubFolder := '';
                  SopItem := WmsCreateMediaItem(SopAddressItem.items[k].Value,
                                                sFolderID,
                                                sFolderPath + sSubFolder);
                  SopItem.Properties[mpiTitle] := sChannelInfo;
                  SopItem.Properties[mpiTranscodingProfile] := sTranscodingProfile
    WmsDatabaseAutoSave
  finally
    XmlDocument.Free
  ProcessMediaResult := True
2. Ok,Ok,Ok
3. Press button "SopCast Channels"
Top
PostPosted: Wed Jan 27, 2010 11:43 pm
I,ve tried this. Does not seem to work. Must be doing something wrong. I've WMS on Server 2008 x64. Maybe Sopcast filter does not work on x64?
Top
PostPosted: Thu Jan 28, 2010 7:05 am
Program 32-bit, uses 32-bit filter. Perhaps you first need to try SopCast player, but I did not install.
Top
PostPosted: Fri Jan 29, 2010 8:54 pm
Player working fine on x64. What can I do? Does it work for you with that code you provided? When I test transcode nothing happens. Where does http://localhost:8902/tv.asf go to? Sop filter works fine with Windows Media Player.
Top
PostPosted: Fri Jan 29, 2010 9:55 pm
Testtranscoding working now. I think it had to be enabled in Windows Media Player first or something . Streaming to tv or PS3 still not working though.
Top
Search for:
Jump to:
cron
