E-Mail Us
It is currently Fri Jan 27, 2023 1:15 am
Post new topic  Reply to topic  [ 1 post ]
Author Message
PostPosted: Sat Jul 16, 2022 2:19 pm
Update to 6.09 (x32) (6.08-6.09)
Update to 6.09 (x64) (6.08-6.09)
Wild Media Server (UPnP, DLNA, HTTP) v.6.09
1. Settings - Server - Web-navigation:
  • added setting "Local root directory" - sets the location files to support Web-navigation, can be used to implement custom Web-navigation.
2. Device settings - Web-Navigation:
  • added the mode "Using the program's Web API", disabled by default.
3. Updated Web-navigation script, added support for the program's Web API methods, responses in JSON-format.
4. Added the Web-navigation implementation using the program's Web API (file location: "Program installation directory" \ Presentation \ WebAPI), implemented features:
  • select and play media files in the HTML5 player of Interner browser, playback using an adapted version of "Photobox viewer";
  • playlist formation of DMR devices using "Drag & Drop";
  • DMR device control.
5. Updated subtitles module.
6. Updated add-on "FFPlay" module.
7. For Linux, the ability to install the service has been added (server operation without starting of the main program).
Top
Search for:
Jump to:
cron
Copyright 2009-2023 Wild Media Server Powered by phpBB® Forum Software © phpBB Limited
