E-Mail Us
It is currently Sun Jul 21, 2019 9:44 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
Author Message
PostPosted: Sun May 07, 2017 12:56 pm
Update to 3.01 (x32) (2.86-3.02) (3.01-3.02)
Update to 3.01 (x64) (2.86-3.02) (3.01-3.02)
Wild Media Server (UPnP, DLNA, HTTP) v.3.00-3.01
1. Media resources (navigation on media device):
  • added folder "UPnP (DLNA) servers":
    • the ability to play media resources UPnP (DLNA) servers found on your home network via a Web navigation;
    • the ability to play media resources with transcoding;
    • the ability to play music and photos through folders Music (Visualization) and Photo (Slideshow).
    In each folder there is the folder "Settings":
    • Transfer mode selection of media resources:
      • Transcoding;
      • Original link;
      • Original stream;
      • Original link (redirect);
    • selection mode "Create Item Folder" (folder contains all the media resource formats, that provides source media server);
    • selection frame height for transcoding.
2. Settings - Transcoder - "Format parameters":
  • added the ability to disable unused formats;
  • added the ability moving format using the "mouse" to desired position.
3. Device settings - General - "Media-resources":
  • If the mode "Include in the description of supported files the links with transcoding" is turned on, the program includes to a UPnP (DLNA) description of a media resource links with transcoding into all active formats from the page Settings - Transcoder - "Format parameters".
Top
Search for:
Jump to:
cron
