E-Mail Us
It is currently Wed Jun 26, 2019 8:07 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
Author Message
PostPosted: Sat Dec 20, 2014 12:52 pm
Update to 2.01 (x32)
Update to 2.01 (x64)
Wild Media Server (UPnP, DLNA, HTTP) v.2.01
1. In the distribution kit of the program included music visualization modules MilkDrop2 (DirectX) and ProjectM (OpenGL).
Visualization modules MilkDrop2 and ProjectM require working with the computer video card, ie do not work through
Remote Desktop Connection and locked computer. Visualizations can hang on Wi-Fi connections.
Top
PostPosted: Mon Jan 05, 2015 3:48 pm
Update to 2.02 (x32)
Update to 2.02 (x64)
1. Various fixes
Top
PostPosted: Fri Jan 16, 2015 8:43 pm
Update to 2.03 (x32)
Update to 2.03 (x64)
1. Updated transcoder ffmpeg-1.dll (version 2.3.3).
Top
PostPosted: Sat Jan 24, 2015 8:38 pm
Update to 2.04 (x32)
Update to 2.04 (x64)
1. Device Settings - Additional:
  • added section "Events":
    • "Formation of DIDL-Lite description of media resources" (before and after), used variables DIDL_XmlItem, DIDL_XmlParentItem, CurrentMediaItem;
    • "Processing HTTP-requests" (before and after), used variables HttpRequest, HttpResponse;
Events can be used to add, modify descriptions of media resources, change HTTP-header of server response. If an event handler "before" back in the variable ProcessEventResult value True, the default processing and event "after" are not executed.
Top
PostPosted: Fri Jan 30, 2015 7:51 pm
Update to 2.05 (x32)
Update to 2.05 (x64)
- fixed a problem with the test transcoding for devices without individual settings.
Top
Search for:
Jump to:
cron
