E-Mail Us
It is currently Wed Dec 01, 2021 7:26 pm
Post new topic  Reply to topic  [ 13 posts ]  Go to page Previous 1 2
Author Message
PostPosted: Wed Dec 22, 2010 1:26 pm
Ubuntu 10.04 LTS -the Lucid Lynx, Wine 1.3.9
After http://www.wildmediaserver.com/forum/vi ... 3613#p3613 no problems
Top
PostPosted: Wed Dec 22, 2010 4:13 pm
I guess your terse message is to mean that you tried it?
As I said in my message ("Installed the certificate as suggested..."), I had done exactly as you suggested in the message you refer to, but it made no change to the failure to start up or give diagnostics about that failure. In addition (i.e., it made it arguably worse), there is now the diagnostic message "Program file is corrupted. It is recommended to reinstall the program from the distribution kit.". The latter message is already part of the GUI startup, i.e., it shows up before any attempt to start the server.
I am running the 64 bit version of Ubuntu 10.04, just in case this makes a difference.
Is there any way to switch on more diagnostics?
Top
PostPosted: Thu Dec 23, 2010 9:11 am
http://www.ubuntu.com/desktop/get-ubuntu/download - 64 bit
I reproduced the problem: I skip the step 5
5. Click "Trusted Root Certification Authorities"
Now, no problems on 64-bit
Top
Search for:
Jump to:
cron
