E-Mail Us
It is currently Sat Jan 19, 2019 3:09 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
Author Message
PostPosted: Sat Jun 25, 2011 7:11 pm
Thanks for this topic. Amazing stuff indeed.
Top
PostPosted: Sun Sep 11, 2011 5:00 pm
While performing the script install (top of this thread) i said yes to clear current scripts instead of no (i'm a dum newbie). It was all of the default scripts that came with the fresh install. I cannot get podcasts to work, could that be the source of my problem? Is there an easy way to get the original scripts back in place without having to reinstall?
_________________
Windows 7 SP1 (x64), MB Asus P5Q-E, Onboard ADI AD2000B audio, 4G ram
NVIDIA GeForce 9800 GTX,Core2 Quad Q9400, Linksys E1550 Router - WiFi n
Samsung LN46C630KLF TV
Top
PostPosted: Sun Sep 11, 2011 5:39 pm
Close the program
My Computer - C:\Program Data\Wild Media Server - delete wmsprocm.cfg (Windows 7)
Top
PostPosted: Sun Sep 11, 2011 5:51 pm
Will this kill the scripts that i have loaded (eg StreamDB, JLC's channels and wwwitv)?
_________________
Top
PostPosted: Sun Sep 11, 2011 6:10 pm
You can load from ?:\Program Files\Wild Media Server\wmsprocm.cfg
Top
PostPosted: Sun Sep 11, 2011 6:36 pm
Thanks for the help. Having problems getting podcasts to work. My TV either says "File format not supported" with some trancode profiles or the TV just restarts (i assume it crashed) back on standard TV mode (ie not playing from the media server). Is there any of these scripts that i should have turned on to make podcasts work? I have StreamDB, JLC channels and wwwiTV checked in the profiles page but no others. Or is my problem with podcasts unrelated to these scripts?
_________________
Top
PostPosted: Sun Sep 11, 2011 7:02 pm
I think it needs more concrete information (StreamDB, JLC channels, wwwiTV, link)
Top
PostPosted: Sun Sep 11, 2011 7:14 pm
I searched the forum for a "How to" for podcasts but didn't find anything. I have tried podcast with many different trancode profiles with minimal results. 99% of the podcasts dont' work. the few that i have managed to work were with the tsmux movies transcode profile but that isn't consistent either. I am mostly trying to get the dailymotion podcast work as my first test. Is there a basic tutorial on how to set up WMS for podcasts somewhere? By the way i am enjoying the program and if i can get a little more comfortable with using it i intend to buy. My biggest complaint would have to be that the documentation / help is a bit difficult to understand in some cases. If you had some "How to" tutorials it would be helpful for novices like me.
_________________
Top
PostPosted: Sun Sep 11, 2011 7:26 pm
Each podcast has instructions on its installation. If 99% does not work, then perhaps luck was against you :)
Top
Search for:
Jump to:
cron
